Certifying Term Rewriting Proof in ELAN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Term rewriting has been shown to be a good environment for both programming and proving. We consider the proof term of term rewriting and propose a formalism based on the rewriting calculus with explicit substitutions ($\rho\sigma$-calculus). This formalism is helpful in analysing and in debugging rule-based programs. Moreover, term rewriting proofs can be exported to other systems by translating them into the corresponding syntaxes. That is, using a proof checker, one can certify these proofs and vice versa, this method allows us to get term rewriting in proof assistants using an external system. Our method not only works with syntactic term rewriting but also with term rewriting modulo a set of axioms ({\em e.g.} associativity-commutativity).
A01-R-138.pdf (352.34 Ko) Télécharger le fichier
inria-00107875 , version 1 (19-10-2006)
  • HAL Id : inria-00107875 , version 1
Quang-Huy Nguyen. Certifying Term Rewriting Proof in ELAN. 2nd International Workshop on Rule-based Programming - RULE'01, Sep 2001, Firenze, Italy, 18 p. ⟨inria-00107875⟩
104 Consultations
51 Téléchargements
