New interface
Conference papers
Field Programmable Processor Arrays
Pascal Nussbaum 1 Bernard Girau 2 Arnaud Tisserand 1
2 CORTEX - Neuromimetic intelligence
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The FPPA concept has been developed in 1996 to address two main goals. The first one is to develop massively parallel processing unit arraya that require large chip areas, and the second one is to obtain a good substratum for evolutive algorithms. The proposed solution is an array of cells, in which each cell contains a small low-power processor and a hierarchy of memories. The FPPA is a single-chip MIMP machine that should be considered as a very coarse grain FPGA.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00108032
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Thursday, October 19, 2006 - 3:40:17 PM
Last modification on : Friday, February 4, 2022 - 3:32:26 AM
Identifiers
  • HAL Id : inria-00108032, version 1
Collections
Citation
Pascal Nussbaum, Bernard Girau, Arnaud Tisserand. Field Programmable Processor Arrays. ICES, 1998, none, France. 12 p. ⟨inria-00108032⟩
Share
Metrics
Record views
117
