Journal articles
Global system analysis at work
Dominique Colnet 1 Olivier Zendra 1
1 MIRHO - Objects, types and prototypes : semantics and validation
CRISAM - Inria Sophia Antipolis - Méditerranée , UHP - Université Henri Poincaré - Nancy 1, Université Nancy 2, INPL - Institut National Polytechnique de Lorraine, CNRS - Centre National de la Recherche Scientifique : UMR7503
Abstract : SmallEiffel, a highly successful open-source implementation of Eiffel developed under the direction of Dominique Colnet at LORIA in France, uses a number of particularly original and innovative compilation techniques. In this article Colnet and his colleague Olivier Zendra raise the veil and show how they have taken advantage of global system analysis techniques to achieve a high degree of performance in the SmallEiffel compilation process and the resulting code.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00108074
Contributor : Publications Loria Connect in order to contact the contributor
Submitted on : Thursday, October 19, 2006 - 3:40:46 PM
Last modification on : Friday, February 4, 2022 - 3:12:14 AM
Identifiers
  • HAL Id : inria-00108074, version 1
Collections
Citation
Dominique Colnet, Olivier Zendra. Global system analysis at work. Journal of Object Oriented Programming, Journal of Object-Oriented Programming, 2001, 14 (1), pp.10--13. ⟨inria-00108074⟩
Share
Metrics
Record views
88
