Interac-DEC-MDP: Towards the use of interactions in DEC-MDP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Vincent Thomas
Christine Bourjot
  • Fonction : Auteur
  • PersonId : 830457
Vincent Chevrier
This article presents a new formalism Interac-DEC-MDP whose aim is to introduce the concept of interaction in Decentralized Markov Decision Process and which has been inspired by biology. The aim of this formalism, Interac-DEC-MDP, is to describe and represent interactions among agents. The outcome of interactions is decided collectively by two agents and is in charge of the distribution of local rewards. We have modeled a biological experiment within this formalism. A simple learning algorithm applied on this formalism generates a more efficient collective behavior than without interactions.
Fichier non déposé
inria-00108104 , version 1 (19-10-2006)
  • HAL Id : inria-00108104 , version 1
Vincent Thomas, Christine Bourjot, Vincent Chevrier. Interac-DEC-MDP: Towards the use of interactions in DEC-MDP. Third International Joint Conference on Autonomous Agents and Multi-Agent Systems - AAMAS'04, 2004, New York, USA, pp.1450-1451. ⟨inria-00108104⟩
175 Consultations
0 Téléchargements
