Evaluation of Handwriting Similarities Using Hermite Transform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this paper, we present a new method for handwriting documents denoising and indexing. This work is based on the Hermite Transform, which is a polynomial transform and a good model of the human visual system (HVS). We use this transformation to analyze handwritings using their visual aspect of texture. We apply this analysis to document indexing (finding documents coming from the same author) or document classification (grouping document containing handwritings that have similar visual aspect). It is often necessary to clean these documents before the analyze step. For that purpose, we use also the Hermite decomposition. The current results are very promising and show that it is possible to characterize handwritten drawings without any a priori graphemes segmentation.
cr1116253068448.pdf (1.33 Mo) Télécharger le fichier
inria-00108345 , version 1 (20-10-2006)
  • HAL Id : inria-00108345 , version 1
Stéphane Bres, Véronique Eglin, Catherine Volpilhac-Auger. Evaluation of Handwriting Similarities Using Hermite Transform. Tenth International Workshop on Frontiers in Handwriting Recognition, Université de Rennes 1, Oct 2006, La Baule (France), France. ⟨inria-00108345⟩
246 Consultations
188 Téléchargements
