Performance Prediction in a Grid Environment, European Across Grids Conference, 2003. ,
DOI : 10.1007/978-3-540-24689-3_32
Simple object access protocol 2 http://simgrid.gforge.inria.fr/ (SOAP) 1.1, World Wide Web Consortium, 2000. ,
Scheduling Distributed Applications: the SimGrid Simulation Framework, IEEE Int ,
URL : https://hal.archives-ouvertes.fr/hal-00789451
Parallelized direct execution simulation of message-passing parallel programs, IEEE Transactions on Parallel and Distributed Systems, vol.7, issue.10, pp.1090-1105, 1996. ,
DOI : 10.1109/71.539740
Native data representation: an efficient wire format for high-performance distributed computing, IEEE Transactions on Parallel and Distributed Systems, vol.13, issue.12, pp.1234-1246, 2002. ,
DOI : 10.1109/TPDS.2002.1158262
Globus Toolkit Version 4: Software for Service-Oriented Systems, Int. Conf. on Network and Parallel Computing, pp.2-13, 2005. ,
The Physiology of the Grid, 2002. ,
DOI : 10.1002/0470867167.ch8
Modularization and McCabe's Cyclomatic Complexity, Communications of the ACM, vol.37, issue.12, pp.17-19, 1992. ,
A performance tool for distributed virtual sharedmemory systems, IASTED Int. Conf. Parallel and Distributed Computing and Systems, 2002. ,
Macedon: Methodology for automatically creating, evaluating, and designing overlay networks, Networked Systems Design and Implementation (USENIX/ACM), 2004. ,
Pastry: Scalable, Decentralized Object Location, and Routing for Large-Scale Peer-to-Peer Systems, LNCS, 2001. ,
DOI : 10.1007/3-540-45518-3_18
The NWS: A Distributed Resource Performance Forecasting Service for Metacomputing, Future Generation Computing Systems, Metacomputing Issue, vol.15, pp.5-6757, 1999. ,
The MicroGrid: Using Emulation to Predict Application Performance in Diverse Grid Network Environments, Workshop on Challenges of Large Applications in Distributed Environments, 2004. ,
