Analysis and Low-order Modeling of the Three-dimensional Flow Past a Confined Square Cylinder - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
The laminar flow past a square cylinder symmetrically placed between two parallel walls is considered. A classical vortex wake is shed from the cylinder, but three-dimensional instabilities are present and they develop in complicated flow patterns. The possibility of extracting an accurate low-order model of this flow is explored.
RR-6004.pdf (1.31 Mo) Télécharger le fichier
inria-00109345 , version 1 (24-10-2006)
inria-00109345 , version 2 (26-10-2006)
  • HAL Id : inria-00109345 , version 2
Marcelo Buffoni, Simone Camarri, Angelo Iollo, Maria-Vittoria Salvetti. Analysis and Low-order Modeling of the Three-dimensional Flow Past a Confined Square Cylinder. [Research Report] RR-6004, INRIA. 2006. ⟨inria-00109345v2⟩
76 Consultations
164 Téléchargements
