Optimal rotary control of the cylinder wake using proper orthogonal decomposition reduced-order model, Physics of Fluids, vol.17, issue.9, p.97101, 2005. ,
DOI : 10.1063/1.2033624
Accurate computations of the laminar flow past a square cylinder based on two different methods: lattice-Boltzmann and finite-volume, International Journal of Heat and Fluid Flow, vol.21, issue.2, pp.186-196, 2000. ,
DOI : 10.1016/S0142-727X(99)00081-8
On the inversion of the von K??rm??n street in the wake of a confined square cylinder, Journal of Fluid Mechanics, vol.574, 2006. ,
DOI : 10.1017/S0022112006004058
A low-diffusion MUSCL scheme for LES on unstructured grids, Computers & Fluids, vol.33, issue.9, pp.1101-1129, 2004. ,
DOI : 10.1016/j.compfluid.2003.10.002
URL : https://hal.archives-ouvertes.fr/hal-00372840
Accurate model reduction of transient flows, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00070337
Low-order modelling of laminar flow regimes past a confined square cylinder, Journal of Fluid Mechanics, vol.503, pp.161-170, 2004. ,
DOI : 10.1017/S0022112004007906
Optimal control of vortex shedding using low-order models. Part I?open-loop model development, International Journal for Numerical Methods in Engineering, vol.111, issue.224, pp.945-972, 1998. ,
DOI : 10.1002/(SICI)1097-0207(19990310)44:7<945::AID-NME537>3.0.CO;2-F
On the behaviour of upwind schemes in the low mach number limit. Computers and Fluids, pp.63-86, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-00871725
The structure of inhomogeneous turbulent flows, Atmospheric Turbulence and Radio Wave Propagation, pp.166-178, 1967. ,
Characteristics of square cylinder wake transition flows, Physics of Fluids, vol.15, issue.9, pp.2549-2559, 2003. ,
DOI : 10.1063/1.1596413
A low-dimensional model for simulating three-dimensional cylinder flow, Journal of Fluid Mechanics, vol.458, pp.181-190, 2002. ,
DOI : 10.1017/S0022112002007991
A second order defect correction scheme for unsteady problems, Computers & Fluids, vol.25, issue.1, pp.9-27, 1996. ,
DOI : 10.1016/0045-7930(95)00027-5
URL : https://hal.archives-ouvertes.fr/inria-00074228
Three-dimensional Floquet instability of the wake of square cylinder, Physics of Fluids, vol.11, issue.3, pp.560-578, 1999. ,
DOI : 10.1063/1.869930
Approximate Riemann solvers, parameter vectors, and difference schemes, Journal of Computational Physics, vol.43, issue.2, pp.357-372, 1981. ,
DOI : 10.1016/0021-9991(81)90128-5
Three-dimensional study of flow past a square cylinder at low Reynolds numbers, International Journal of Heat and Fluid Flow, vol.24, issue.1, pp.54-66, 2003. ,
DOI : 10.1016/S0142-727X(02)00208-4
Turbulence and the dynamics of coherent structures. Parts I,II and III, Quarterly of Applied Mathematics, pp.561-590, 1987. ,
Simulation of three-dimensional flow around a square cylinder at moderate Reynolds numbers, Physics of Fluids, vol.11, issue.2, pp.288-306, 1999. ,
DOI : 10.1063/1.869879
Analysis and low-order modeling of the inhomogeneous transitional flow inside a T-mixer, Physics of Fluids, vol.16, issue.8, pp.2717-2731, 2004. ,
DOI : 10.1063/1.1751204
Towards the ultimate conservative difference scheme. IV. A new approach to numerical convection, Journal of Computational Physics, vol.23, issue.3, pp.276-299, 1977. ,
DOI : 10.1016/0021-9991(77)90095-X
Flow about a circular cylinder between parallel walls, Journal of Fluid Mechanics, vol.440, pp.1-25, 2001. ,
DOI : 10.1017/S0022112001004608
Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex (France) Unité de recherche INRIA Sophia Antipolis : 2004, route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
