Reports
An inexact conic bundle variant suited to column generation
Abstract : We give a bundle method for constrained convex optimization. Instead of using penalty functions, it shifts iterates towards feasibility, by way of a Slater point, assumed to be known. Besides, the method accepts an oracle delivering function and subgradient values with unknown accuracy. Our approach is motivated by a number of applications in column generation, in which constraints are positively homogeneous -- so that 0 is a natural Slater point -- and an exact oracle may be time consuming. Finally, our convergence analysis employs arguments which have been little used so far in the bundle community. The method is illustrated on a number of cutting-stock problems.
Document type :
Reports
Complete list of metadata
Cited literature [44 references]  Display  Hide  Download
https://hal.inria.fr/inria-00109402
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, November 10, 2006 - 9:59:28 AM
Last modification on : Monday, November 23, 2020 - 12:52:03 PM
Long-term archiving on: : Monday, September 20, 2010 - 4:45:36 PM
Identifiers
  • HAL Id : inria-00109402, version 2
Collections
Citation
Krzysztof Kiwiel, Claude Lemarechal. An inexact conic bundle variant suited to column generation. [Research Report] RR-6011, INRIA. 2006. ⟨inria-00109402v2⟩
Share
Metrics
Record views
270
Files downloads
319
