Moments conservation in adaptive Vlasov solver - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nuclear Instruments and Methods in Physics Research Année : 2006
We previously developed an adaptive semi-Lagrangian solver using a multiresolution analysis based on interpolets which are a kind of interpolating wavelets introduced by Deslauriers and Dubuc. This paper introduces a new multiresolution approximation for this solver which allows to conserve moments up to any order by using the lifting method introduced by Sweldens.
Proc_ICAP.pdf (303.82 Ko) Télécharger le fichier
inria-00110757 , version 1 (31-10-2006)
Michaël Gutnic, Matthieu Haefele, Eric Sonnendrücker. Moments conservation in adaptive Vlasov solver. Nuclear Instruments and Methods in Physics Research, 2006, Proceedings of the 8th International Computational Accelerator Physics Conference - ICAP 2004, 558 (1), pp.159-162. ⟨10.1016/j.nima.2005.11.225⟩. ⟨inria-00110757⟩
106 Consultations
157 Téléchargements
