Evaluation of phonetic constraints used in acoustic-to-articulatory inversion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
One of the main challenges in acoustic-to-articulatory inversion is the incorporation of constraints in order to reduce the under-determination of the problem. This paper is dedicated to the evaluation of phonetic constraints we proposed in a previous work. The vocal tract shapes recovered for three vowels uttered by a female speaker, the speech signal together with X-ray images are available for, were analyzed. It turns out that the phonetic constraints derived from standard phonetic knowledge are quite efficient to keep relevant vocal tract shapes. In addition, acoustic-to-articulatory inversion appears to be an efficient evaluation tool to explore the acoustical properties of an articulatory model.
Fichier non déposé
inria-00112225 , version 1 (07-11-2006)
  • HAL Id : inria-00112225 , version 1
Yves Laprie, Blaise Potard, Anne Bonneau. Evaluation of phonetic constraints used in acoustic-to-articulatory inversion. 7th International Seminar on Speech Production - ISSP 2006, Dec 2006, Sao Paulo/Brésil. ⟨inria-00112225⟩
70 Consultations
0 Téléchargements
