Rewriting-Based Access Control Policies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this paper we propose a formalization of access control policies based on term rewriting. The state of the system to which policies are enforced is represented as an algebraic term, what allows to model many aspects of the policy environment. Policies are represented as sets of rewrite rules, whose evaluation produces deterministic authorization decisions. We discuss the relation between properties of \trs and those important for access control, and the impact of composing policies to these properties.
secret2006.pdf (182.37 Ko) Télécharger le fichier
inria-00112340 , version 1 (09-11-2006)
  • HAL Id : inria-00112340 , version 1
Anderson Santana de Oliveira. Rewriting-Based Access Control Policies. 1st International Workshop on Security and Rewriting Techniques - SecReT 2006, Maribel Fernández, Sep 2006, Venice/Italy. ⟨inria-00112340⟩
62 Consultations
235 Téléchargements
