Applying new scheduling theory to static priority pre-emptive scheduling, Software Engineering Journal, vol.8, issue.5, 1993. ,
DOI : 10.1049/sej.1993.0034
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.132.2794
Scheduling tasks with precedence constraints to solicit desirable bid combinations, Proceedings of the second international joint conference on Autonomous agents and multiagent systems , AAMAS '03, 2003. ,
DOI : 10.1145/860575.860631
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.57.6363
Scheduling dependent tasks with different arrival times to meet deadlines " . Modelling and Performance Evolution of Computer Systems, 1976. ,
Building reliable component-based software systems " . Artech House ,
Schedulability condition for systems with precedence and periodicity constrainsts without preemption " . RTS2003, 11th conference on Real-time and embedded systems, 2003. ,
A dynamic priority assignment technique for streams with (m, k)-firm deadlines, IEEE Transactions on Computers, vol.44, issue.12, p.14431451, 1995. ,
DOI : 10.1109/12.477249
Function Blocks for Industrial Process Measurements and Control Systems " . Committee Draft, 2003. ,
Industrial Process Measurements and Control Systems " . Committee Draft, 2004. ,
On Non-Preemptive Scheduling of Periodic and Sporadic Tasks, Proc. of the 12th IEEE Real-Time Systems Symposium, pp.129-139, 1991. ,
A behavior model for IEC 61499 function blocks, Third Workshop on Modelling of Objects, Components and Agents. Denmark, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00100263
A schedulability analysis of an IEC61499 control application, 6th IFAC International Conference on Fieldbus Systems and their Applications. Fet2005. Mexico, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00000492
The notion of end-to-end capacity and its application to the estimation of end-toend network delays, Computer Networks: The International Journal of Computer and Telecommunications Networking, vol.48, issue.3, pp.475-488, 2005. ,
A practioner's handbook for real-time analysis " . Guide to Rate Monotonic Analysis for Real-Time Systems, 1993. ,
Optimal sequencing of a single machine subject to precedence constraints " . Management Science, 1973. ,
The rate monotonic scheduling algorithm: exact characterization and average case behavior, [1989] Proceedings. Real-Time Systems Symposium, 1989. ,
DOI : 10.1109/REAL.1989.63567
On the complexity of fixedpriority scheduling of periodic real-time tasks, Performance Evaluation, vol.2, p.237250, 1982. ,
Modelling Control systems using IEC 61499 " . The Institution Of Electrical Engineers ,
Scheduling Algorithms for Multiprogramming in a Hard-Real-Time Environment, Journal of the ACM, vol.20, issue.1, pp.46-61, 1973. ,
DOI : 10.1145/321738.321743
Real-Time Systems Fault-Tolerant Real-Time Scheduling under Execution Time Constraints, Sixth International Conference on Real-Time Computing Systems and Applications (RTCSA'99), Hongkong, 1999. ,
Off-Line scheduling of real-time applications with variable duration tasks, 7th Workshop on Discrete Events Systems, pp.373-378, 2004. ,
A New Timing Schema for WCET Analysis, 4th international workshop on worst-case execution time analysis (WCET2004) in conjunction with the 16th Euromicro Intl Conference on Real-Time Systems (ECRTS2004) ,
Off-line scheduling of a real-time system, Proceedings of the 1998 ACM symposium on Applied Computing , SAC '98, 1998. ,
DOI : 10.1145/330560.330566
Deadline Scheduling For Real-Time Systems ,
DOI : 10.1007/978-1-4615-5535-3
??ITRON for small-scale embedded systems, IEEE Micro, vol.15, issue.6, pp.46-54, 1995. ,
DOI : 10.1109/40.476258
