An optimal memory allocation scheme for scratch-pad-based embedded systems, ACM Transactions on Embedded Computing Systems, vol.1, issue.1, pp.6-26, 2002. ,
DOI : 10.1145/581888.581891
Scratchpad memory, Proceedings of the tenth international symposium on Hardware/software codesign , CODES '02, pp.73-78, 2002. ,
DOI : 10.1145/774789.774805
Compiler-directed array interleaving for reducing energy in multi-bank memories, Proceedings of ASP-DAC/VLSI Design 2002. 7th Asia and South Pacific Design Automation Conference and 15h International Conference on VLSI Design, p.288, 2002. ,
DOI : 10.1109/ASPDAC.2002.994936
« Heap Data Allocation to Scratch-Pad Memory in Embedded Systems, Journal of Embedded Computing, 2005. ,
Power aware computing, 2002. ,
DOI : 10.1007/978-1-4757-6217-4
Inter-program optimizations for conserving disk energy, Proceedings of the 2005 international symposium on Low power electronics and design , ISLPED '05, pp.335-338, 2005. ,
DOI : 10.1145/1077603.1077684
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.75.1789
« Register relabeling : A post compilation technique for energy reduction. », Workshop on Compilers and Operating Systems for Low Power, 2000. ,
Partitioning Variables across Register Windows to Reduce Spill Code in a Low-Power Processor, Partitioning Variables across Register Windows to Reduce Spill Code in a Low-Power Processor, pp.998-1012, 2005. ,
DOI : 10.1109/TC.2005.132
Intraprogram dynamic voltage scaling, ACM Transactions on Architecture and Code Optimization, vol.1, issue.3, pp.323-367, 2004. ,
DOI : 10.1145/1022969.1022973
Data Compression Transformations for Dynamically Allocated Data Structures, Proceedings of the 11th International Conference on Compiler Construction (CC'02), pp.14-28, 2002. ,
DOI : 10.1007/3-540-45937-5_4
Storage assignment optimizations through variable coalescence for embedded processors, LCTES '03 : Proceedings of the 2003 ACM SIGPLAN conference on Language, Compiler, and Tool for Embedded Systems, pp.220-231, 2003. ,
DOI : 10.1145/780731.780763
