Development of an in-vehicle middleware
Ricardo Santos Marques 1 Françoise Simonot-Lion 1 Nicolas Navet 1
1 TRIO - Real time and interoperability
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : In the context of in-vehicle embedded systems, a middleware layer is intended to mask the heterogeneity of platforms and to provide high level communication services to applicative tasks. In addition, it is a software architecture shared between car makers and third-part suppliers, ensuring the portability and interoperability of the applicative level components. In this context, the interoperability covers the interfaces between components, and also, the guarantee that at run-time, tasks implementing these components and their data exchanges respect all the required timing constraints (i.e. timing interoperability). This study presents a method aiming at developing the middleware's architecture, and obtaining feasible scheduling parameters for network frames (specifically for CAN frames) and middleware and applicative tasks. The architecture is built from a set of design patterns and is represented by a class diagram that specifies the software components implementing the middleware services. Then, from the events that are handled by the middleware, tasks providing the communication services are precisely identified and a possible implementation targeted at OSEK/VDX OS is discussed. Finally, the scheduling parameters of frames and tasks are determined in such a way that timing constraints on tasks and signals are ensured to be met.
Type de document :
Chapitre d'ouvrage
Holger Giese and Oliver Niggemann. Object-oriented Modeliing of Embedded Real-Time Systems 3, Heinz Nixdorf Institut, 2006, HNI-Verlagsschriftenreihe, 3-939350-10-9
Liste complète des métadonnées
https://hal.inria.fr/inria-00113588
Contributeur : Nicolas Navet <>
Soumis le : lundi 13 novembre 2006 - 18:26:36
Dernière modification le : jeudi 11 janvier 2018 - 06:20:05
  • HAL Id : inria-00113588, version 1
Collections
Citation
Ricardo Santos Marques, Françoise Simonot-Lion, Nicolas Navet. Development of an in-vehicle middleware. Holger Giese and Oliver Niggemann. Object-oriented Modeliing of Embedded Real-Time Systems 3, Heinz Nixdorf Institut, 2006, HNI-Verlagsschriftenreihe, 3-939350-10-9. 〈inria-00113588〉
Métriques
Consultations de la notice
162
