Ahead of time deployment in ROM of a Java-OS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This article shows how it is possible to place a great part of a Java system in read-only memory in order to fit with the requirements of tiny devices. Java systems for such devices are commonly deployed off-board, then embedded on the target device in a ready-to-run form. Our approach is reach an advanced state of deployment off-board, which allows us to maximize the amount of data placed in read-only memory. Doing so, we are also able to reduce the overall size of the system.
marquet-icess-05.pdf (104.72 Ko) Télécharger le fichier
inria-00113693 , version 1 (14-11-2006)
  • HAL Id : inria-00113693 , version 1
Kévin Marquet, Alexandre Courbot, Gilles Grimaud, David Simplot-Ryl. Ahead of time deployment in ROM of a Java-OS. 2nd International Conference on Embedded Software and System (ICESS 2005), 2005, Xi'an, China. ⟨inria-00113693⟩
106 Consultations
605 Téléchargements
