Reports
Some applications of $l^\infty$-constraints in image processing
Pierre Weiss 1 Gilles Aubert 2 Laure Blanc-Féraud 1
1 ARIANA - Inverse problems in earth monitoring
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - SIS - Signal, Images et Systèmes
Abstract : Our goal in this paper is to give algorithms for minimizing generic regularizing functionals under a $l^\infty$-constraint. We show that many classical models using total variation can be stated under this formalism. Among others are the Rudin-Oscher-Fatemi model, the BV-l1 model, BV-$l^\infty$ model and Meyer's cartoon +texture decomposition model. Then we describe a general convergence algorithm to solve such problems. This algorithm is the projected subgradient descent. We finally give numerical results that show the qualities and limits of our model, and we tackle the question of the use of the total variation to treat bounded noises such as quantization noise.
Document type :
Reports
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00114051
Contributor : Pierre Weiss Connect in order to contact the contributor
Submitted on : Friday, February 9, 2007 - 1:49:17 PM
Last modification on : Sunday, May 1, 2022 - 3:14:53 AM
Long-term archiving on: : Tuesday, September 21, 2010 - 11:59:47 AM
File
RR-6115.pdf
Identifiers
  • HAL Id : inria-00114051, version 2
Citation
Pierre Weiss, Gilles Aubert, Laure Blanc-Féraud. Some applications of $l^\infty$-constraints in image processing. [Research Report] RR-6115, INRIA. 2006, pp.33. ⟨inria-00114051v2⟩
Share
Metrics
Record views
203
Files downloads
356
