A New Method for Determining Fixed Priority Configurations for Real-Time Systems on Multiprocessor Targets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2007
We present a new method, called PFX, for determining fixed priority configurations on multiprocessor targets. PFX follows an off-line approach: our constructive process uses an inductive analysis of the whole set of possibilities and the exact evolution parameters of tasks instead of response times. Experimentations show that PFX is very efficient on multiprocessor systems and subsumes RM, DM as well as ED, and also found configurations only schedulable by PFX : using RM, DM, ED or LL lead to miss some deadlines !
Fichier non déposé
inria-00115123 , version 1 (20-11-2006)
  • HAL Id : inria-00115123 , version 1
Bernard Chauvière, Dominique Geniet, René Schott. A New Method for Determining Fixed Priority Configurations for Real-Time Systems on Multiprocessor Targets. 2007. ⟨inria-00115123⟩
143 Consultations
0 Téléchargements
