HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Investigation of Ethernet switches behavior in presence of contending flows at very high-speed
Sebastien Soudan 1, 2 Romaric Guillier 1, 2 Ludovic Hablot 2, 1 Yuetsu Kodama 3 Tomohiro Kudoh 3 Fumihiro Okazaki 3 Pascale Primet 1, 2 Ryousei Takano 3
2 RESO - Protocols and softwares for very high-performance network
Inria Grenoble - Rhône-Alpes, ENS Lyon - École normale supérieure - Lyon, CNRS - Centre National de la Recherche Scientifique : UMR5668
Abstract : This paper examines the interactions between layer 2 (Ethernet) switches and TCP in high bandwidth delay product networks. First, the behavior of a range of Ethernet switches when two long lived connections compete for the same output port is investigated. Then, the report explores the impact of these behaviors on TCP protocol in long and fast networks (LFNs). Several conditions in which scheduling mechanisms introduce heavy unfair bandwidth sharing and loss burst which impact TCP performance are shown.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/inria-00115893
Contributor : Sebastien Soudan Connect in order to contact the contributor
Submitted on : Wednesday, December 13, 2006 - 1:27:25 PM
Last modification on : Friday, February 4, 2022 - 3:18:18 AM
Long-term archiving on: : Thursday, September 23, 2010 - 3:33:40 PM
File
RR-6031.pdf
Identifiers
  • HAL Id : inria-00115893, version 3
Citation
Sebastien Soudan, Romaric Guillier, Ludovic Hablot, Yuetsu Kodama, Tomohiro Kudoh, et al.. Investigation of Ethernet switches behavior in presence of contending flows at very high-speed. [Research Report] INRIA. 2006. ⟨inria-00115893v3⟩
Share
Metrics
Record views
146
Files downloads
110
