A study of large flow interactions in high-speed shared networks with Grid5000 and GtrcNET-10 instruments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We consider the problem of huge data transfers and bandwidth sharing in contexts where transfer delay bounds are required. This report investigates large flow interactions in a real very high-speed network and aims at contributing to high-speed TCP variants evaluation by providing precise measurements. It then also gives an insight on the behaviour of emulated alternative protocols under different realistic congestion and long latency conditions in 10~Gbps experimental environments.
RR-6034.pdf (9.77 Mo) Télécharger le fichier
inria-00116249 , version 1 (24-11-2006)
inria-00116249 , version 2 (27-11-2006)
inria-00116249 , version 3 (28-11-2006)
inria-00116249 , version 4 (06-04-2007)
inria-00116249 , version 5 (19-04-2007)
  • HAL Id : inria-00116249 , version 3
Romaric Guillier, Ludovic Hablot, Yuetsu Kodama, Tomohiro Kudoh, Fumihiro Okazaki, et al.. A study of large flow interactions in high-speed shared networks with Grid5000 and GtrcNET-10 instruments. [Research Report] RR-6034, 2006. ⟨inria-00116249v3⟩
Collections
INRIA-RRRT
139 Consultations
166 Téléchargements
