Extraction d'entités dans des collections évolutives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The goal of our work is to use a set of reports and extract named entities, in our case the names of partners. Starting with an initial list of entities, we use a first set of documents to identify syntactic patterns that are then validated in a supervised learning phase on a set of annotated documents to perform a performance test. The complete collection is then explored. This approach comes from the one that is used in data extraction for semi-structured documents (wrappers) and do not need any linguistic ressources neither a large set for training. As our collection of documents evoluate, we hope that the performance of the extraction becomes better year after year.
etam.pdf (42.96 Ko) Télécharger le fichier
inria-00116910 , version 1 (28-11-2006)
inria-00116910 , version 2 (19-06-2007)
inria-00116910 , version 3 (13-07-2007)
inria-00116910 , version 4 (20-07-2007)
  • HAL Id : inria-00116910 , version 2
  • ARXIV : 0706.2797
Thierry Despeyroux, Eduardo Fraschini, Anne-Marie Vercoustre. Extraction d'entités dans des collections évolutives. 7ièmes Journées francophones Extraction et Gestion des Connaissances EGC 2007, Jan 2007, Namur, Belgique. ⟨inria-00116910v2⟩
109 Consultations
73 Téléchargements
