On the complexity of real root isolation using Continued Fractions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We present algorithmic, complexity and implementation results concerning real root isolation of integer univariate polynomials using the continued fraction expansion of real algebraic numbers. One motivation is to explain the method's good performance in practice. We improve the previously known bound by a factor of $d \tau$, where $d$ is the polynomial degree and $\tau$ bounds the coefficient bit size, thus matching the current record complexity for real root isolation by exact methods (Sturm, Descartes and Bernstein subdivision). Namely our complexity bound is $\sOB(d^4 \tau^2)$ using a standard bound on the expected bit size of the integers in the continued fraction expansion. Moreover, using a homothetic transformation we improve the expected complexity bound to $\sOB( d^3 \tau)$ under the assumption that $d = \OO( \tau)$. We compute the multiplicities within the same complexity and extend the algorithm to non square-free polynomials. Finally, we present an efficient open-source \texttt{C++} implementation in the algebraic library \synaps, and illustrate its completeness and efficiency as compared to other available software. For this we use polynomials with coefficient bit size up to 8000 bits and degree up to 1000.
RR-6059.pdf (374.28 Ko) Télécharger le fichier
inria-00116990 , version 1 (29-11-2006)
inria-00116990 , version 2 (30-11-2006)
inria-00116990 , version 3 (30-11-2006)
inria-00116990 , version 4 (10-12-2006)
inria-00116990 , version 5 (11-12-2006)
inria-00116990 , version 6 (11-12-2006)
  • HAL Id : inria-00116990 , version 5
Elias P. P. Tsigaridas, Ioannis Z. Emiris. On the complexity of real root isolation using Continued Fractions. [Research Report] RR-6059, 2006. ⟨inria-00116990v5⟩
Collections
INRIA-RRRT
156 Consultations
251 Téléchargements
