Efficient collective communication on heterogeneous networks of workstations, Proceedings of the 27th International Conference on Parallel Processing (ICPP'98), 1998. ,
Communication modeling of heterogeneous networks of workstations for performance characterization of collective operations, HCW'99, the 8th Heterogeneous Computing Workshop, pp.125-133, 1999. ,
Scheduling strategies for master-slave tasking on heterogeneous processor platforms, IEEE Trans. Parallel Distributed Systems, vol.15, issue.4, pp.319-330, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00789427
Message multicasting in heterogeneous networks, SIAM Journal on Computing, vol.30, issue.2, pp.347-358, 2000. ,
A proposal for a heterogeneous cluster ScaLAPACK (dense linear solvers), IEEE Trans. Computers, vol.50, issue.10, pp.1052-1070, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00808287
Matrix multiplication on heterogeneous platforms, IEEE Trans. Parallel Distributed Systems, vol.12, issue.10, pp.1033-1051, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00808288
Partitioning a square into rectangles: NP-completeness and approximation algorithms, Algorithmica, vol.34, pp.217-239, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00807407
Centralized versus distributed schedulers for multiple bag-of-task applications, International Parallel and Distributed Processing Symposium IPDPS, 2006. ,
High-performance schedulers, The Grid: Blueprint for a New Computing Infrastructure, pp.279-309, 1999. ,
Efficient collective communication in distributed heterogeneous systems, ICDCS'99 19th International Conference on Distributed Computing Systems, pp.15-24, 1999. ,
Efficient collective communication in distributed heterogeneous systems, Journal of Parallel and Distributed Computing, vol.63, pp.251-263, 2003. ,
ScaLAPACK: A portable linear algebra library for distributed-memory computers -design issues and performance, Supercomputing '96, 1996. ,
, ScaLAPACK Users' Guide. SIAM, 1997.
A cellular computer to implement the Kalman filter algorithm, 1969. ,
Self-organizing scheduling on the organic grid, Int. Journal of High Performance Computing Applications, vol.20, issue.1, pp.115-130, 2006. ,
Self adapting software for numerical linear algebra and lapack for clusters, Parallel Computing, vol.29, pp.1723-1743, 2003. ,
Compile-time scheduling algorithms for heterogeneous network of workstations, The Computer Journal, vol.40, issue.6, pp.356-372, 1997. ,
Customized dynamic load balancing for a network of workstations, Journal of Parallel and Distributed Computing, vol.43, pp.156-162, 1997. ,
Introduction to Algorithms, 1990. ,
Block data decomposition for data-parallel programming on a heterogeneous workstation network, 2nd International Symposium on High Performance Distributed Computing, pp.42-49, 1993. ,
DOI : 10.1109/hpdc.1993.263859
Processes distribution of homogeneous parallel linear algebra routines on heterogeneous clusters, HeteroPar'2005: International Conference on Heterogeneous Computing, 2005. ,
Key concepts for parallel out-of-core LU factorization, Parallel Computing, vol.23, issue.1-2, pp.49-70, 1997. ,
An enabling framework for master-worker applications on the computational grid, Ninth IEEE International Symposium on High Performance Distributed Computing (HPDC'00), 2000. ,
Adaptive scheduling for masterworker applications on the computational grid, Grid Computing -GRID 2000, pp.214-227, 1971. ,
Bandwidth-aware resource allocation for heterogeneous computing systems to maximize throughput, Proceedings of the 32th International Conference on Parallel Processing, 2003. ,
I/O complexity: the red-blue pebble game, STOC '81: Proceedings of the 13th ACM symposium on Theory of Computing, pp.326-333, 1981. ,
Communication lower bounds for distributedmemory matrix multiplication, J. Parallel Distributed Computing, vol.64, issue.9, pp.1017-1026, 2004. ,
Array decomposition for nonuniform computational environments, Journal of Parallel and Distributed Computing, vol.36, pp.91-105, 1996. ,
DOI : 10.1006/jpdc.1996.0092
URL : https://surface.syr.edu/cgi/viewcontent.cgi?article=1004&context=lcsmith_other
Heterogeneous distribution of computations while solving linear algebra problems on networks of heterogeneous computers, LNCS, vol.1593, pp.191-200, 1999. ,
On broadcasting in heterogenous networks, Proceedings of the fifteenth annual ACM-SIAM symposium on Discrete algorithms, pp.1011-1020, 2004. ,
Data partitioning with a realistic performance model of networks of heterogeneous computers, International Parallel and Distributed Processing Symposium IPDPS, 2004. ,
Broadcast scheduling optimization for heterogeneous cluster systems, Journal of Algorithms, vol.42, issue.1, pp.135-152, 2002. ,
DOI : 10.1006/jagm.2001.1204
URL : http://ce.sharif.ac.ir/~ghodsi/archive/d-papers/SPAA/2000/Broadcast scheduling optimization for heterogeneous cluster systems.pdf
Dynamic matching and scheduling of a class of independent tasks onto heterogeneous computing systems, Eight Heterogeneous Computing Workshop, pp.30-44, 1999. ,
Compiler optimization for enhancing parallelism and their impact on architecture design, IEEE Transactions on Computers, vol.37, issue.8, pp.991-1004, 1988. ,
Understanding the behavior and performance of non-blocking communications in MPI, Proceedings of Euro-Par, vol.3149, pp.173-182, 2004. ,
Adaptive scheduling of master/worker applications on distributed computational resources, 2001. ,
Master/slave computing on the grid, Heterogeneous Computing Workshop HCW'00, 2000. ,
A survey of out-of-core algorithms in numerical linear algebra, External Memory Algorithms and Visualization, pp.161-180, 1999. ,
Scheduling multi-component applications in heterogeneous wide-area networks, Heterogeneous Computing Workshop HCW'00, 2000. ,
DOI : 10.1109/hcw.2000.843745
Automatically tuned linear algebra software, Proceedings of the ACM/IEEE Symposium on Supercomputing (SC'98), 1998. ,
DOI : 10.1109/sc.1998.10004
URL : http://www.netlib.org/lapack/lawnspdf/lawn131.pdf
, Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex
LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 ,
