Case-based Reasoning: Foundational Issues, Methodological Variations, and System Approaches. AI Communications, pp.39-59, 1994. ,
Knowledge-Intensive Case-Based Reasoning and Sustained Learning, Proceedings of the 9th European Conference on Artificial Intelligence (ECAI'90), 1990. ,
DOI : 10.1007/978-3-540-28631-8_1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.139.4426
Abstract, The Journal of Symbolic Logic, vol.48, issue.02, pp.510-530, 1985. ,
DOI : 10.1080/00048408412341331
The Description Logic Handbook, 2003. ,
DOI : 10.1017/CBO9780511711787
OWL Web Ontology Language Reference, www.w3.org/TR/owl-ref, 2006. ,
Learning plan abstractions, Lecture Notes in Artificial Intelligence, vol.16, issue.671, pp.92-187, 1992. ,
DOI : 10.1007/BFb0019004
Retrieval Issues in Real-World CBR Applications. How far can we go with discrimination-nets? Reuse of designs: an interdisciplinary cognitive approach, Proceedings of the IJCAI'93 Workshop, 1993. ,
Investigations into a theory of knowledge base revision: Preliminary report, AAAI, pp.475-479, 1988. ,
Adaptation Knowledge Acquisition: a Case Study for Case-Based Decision Support in Oncology, Computational Intelligence (an International Journal), vol.22, issue.34, pp.161-176, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00116888
Case-Based Reasoning within Semantic Web Technologies, Twelfth International Conference on Artificial Intelligence: Methodology, Systems, Applications (AIMSA-06), pp.190-200, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00112090
Case Base Mining for Adaptation Knowledge Acquisition, Proceedings of the 20th International Joint Conference on Artificial Intelligence (IJCAI'07, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00127347
Fuzzy set modelling in case-based reasoning, International Journal of Intelligent Systems, vol.13, issue.4, pp.345-373, 1998. ,
DOI : 10.1002/(SICI)1098-111X(199804)13:4<345::AID-INT3>3.0.CO;2-N
Decision-theoretic foundations of qualitative possibility theory, European Journal of Operational Research, vol.128, issue.3, pp.459-478, 2001. ,
DOI : 10.1016/S0377-2217(99)00473-7
On Applying the AGM Theory to DLs and OWL, Proceedings of the 4th International Semantic Web Conference (ISWC 2005), pp.216-231, 2005. ,
DOI : 10.1007/11574620_18
Learning Physical Domains: Toward a Theoretical Framework, Machine Learning, pp.311-348, 1986. ,
A Knowledge-level Task Model of Adaptation in Case-Based Reasoning, Case- Based Reasoning Research and Development ? Third International Conference on Case-Based Reasoning (ICCBR-99), Lecture Notes in Artificial Intelligence 1650, pp.118-131, 1999. ,
DOI : 10.1007/3-540-48508-2_9
A Substitution-based Adaptation Model, Formalisation of Adaptation in Case-Based Reasoning. Third International Conference on Case-Based Reasoning Workshop, ICCBR-99 Workshop number 3, S. Schmitt and I. Vollrath, 1999. ,
Case-Based Planning: A Framework for Planning from Experience, Cognitive Science, vol.12, issue.1, pp.385-443, 1990. ,
DOI : 10.1207/s15516709cog1403_3
Explaining and repairing plans that fail, Artificial Intelligence, vol.45, issue.1-2, pp.173-228, 1990. ,
DOI : 10.1016/0004-3702(90)90040-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.103.5827
Systems, tasks and adaptation knowledge: Revealing some revealing dependencies, Case-Based Reasoning Research and Development ? First International Conference, ICCBR'95, pp.461-470, 1010. ,
DOI : 10.1007/3-540-60598-3_42
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.17.5271
Using description logics for knowledge intensive case-based reasoning, Advances in Case-Based Reasoning ? Third European Workshop, EWCBR'96, LNAI 1168, pp.204-218, 1996. ,
DOI : 10.1007/BFb0020612
Propositional knowledge base revision and minimal change, Artificial Intelligence, vol.52, issue.3, pp.263-294, 1991. ,
DOI : 10.1016/0004-3702(91)90069-V
On the difference between updating a knowledge base and revising it, KR'91: Principles of Knowledge Representation and Reasoning, pp.387-394, 1991. ,
DOI : 10.1017/CBO9780511526664.007
Case-Based Reasoning, 1993. ,
Reformulations and Adaptation Decomposition Formalisation of Adaptation in Case-Based Reasoning, Third International Conference on Case-Based Reasoning Workshop, ICCBR-99 Workshop number 3, S. Schmitt and I. Vollrath, 1999. ,
Strong, Fuzzy and Smooth Hierarchical Classification for Case-Based Problem Solving, Proceedings of the 15th European Conference on Artificial Intelligence (ECAI-02), pp.81-85, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00107563
An Investigation of Generalized Cases, Proceedings of the 5th International Conference on Case Base Reasoning (ICCBR'03), volume 2689 of LNAI, pp.261-275, 2003. ,
DOI : 10.1007/3-540-45006-8_22
EPISTEMOLOGICAL PROBLEMS OF ARTIFICIAL INTELLIGENCE, Proceedings of the 5th International Joint Conference on Artificial Intelligence (IJCAI'77), pp.1038-1044, 1977. ,
DOI : 10.1016/B978-0-934613-03-3.50035-0
Improving the Revision Stage of a CBR System with Belief Revision Techniques. Computing and information systems journal, pp.40-45, 2001. ,
Using adaptation knowledge to retrieve and adapt design cases. Knowledge-Based Systems, pp.127-135, 1996. ,
DOI : 10.1016/0950-7051(95)01024-6
Case-Based Design, 1996. ,
Statistical Decision Functions., Journal of the American Statistical Association, vol.46, issue.253, 1950. ,
DOI : 10.2307/2280105
URL : http://projecteuclid.org/download/pdf_1/euclid.aoms/1177730030
Techniques and knowledge used for adaptation during case-based problem solving, Methodology and Tools in Knowledge- Based Systems, Proceedings of the 11th International Conference on Industrial, Engineering and Other Applications of Applied Intelligent Systems, 1998. ,
DOI : 10.1007/3-540-64574-8_435
