HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Component-based Design of Heterogeneous Reactive Systems in Prometheus
Abstract : Designing embedded systems increasingly demands coping with heterogeneous systems, involving different models of computation, communication, and execution, on different levels of abstraction and different time scales. The component model BIP (Behavior, Interaction model, Priority) has been designed to support the construction of heterogeneous reactive systems. It enables heterogeneous modeling by separating the notions of behavior, interaction model, and execution model. We present here the design tool Prometheus, which implements the BIP component model, along with a set of algorithms for compositional verification. The use of the component framework is illustrated with two case studies involving different models of computation and communication.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00119245
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Monday, December 11, 2006 - 9:57:55 AM
Last modification on : Friday, February 4, 2022 - 3:15:44 AM
Long-term archiving on: : Monday, September 20, 2010 - 5:58:02 PM
RR-6057.pdf
Identifiers
  • HAL Id : inria-00119245, version 2
Collections
Citation
Gregor Goessler. Component-based Design of Heterogeneous Reactive Systems in Prometheus. [Research Report] RR-6057, INRIA. 2006, pp.18. ⟨inria-00119245v2⟩
Share
Metrics
Record views
70
Files downloads
116
