Automatic deployment of the Network Weather Service using the Effective Network View - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
The monitoring infrastructure constitutes a key component of any Grid scheduler. The Network Weather Service (NWS) is the most commonly used tool to fulfill this need. Unfortunately, users have to deploy the NWS manually, which can be very tedious and error-prone. This paper characterizes the NWS deployment requirements and introduces a method based on the Effective Network View (ENV) network mapper to automatically perform this task. We also present the resulting deployment on our lab's LAN.
ENV-NWS-wgb04.pdf (258.9 Ko) Télécharger le fichier
WGB_slides.pdf (621.44 Ko) Télécharger le fichier
Format : Autre
inria-00119253 , version 1 (08-12-2006)
  • HAL Id : inria-00119253 , version 1
Arnaud Legrand, Martin Quinson. Automatic deployment of the Network Weather Service using the Effective Network View. High-Performance Grid Computing Workshop, associated to IPDPS'04, Apr 2004, Santa Fe, New Mexico, USA. ⟨inria-00119253⟩
158 Consultations
341 Téléchargements
