Embedded harmonic control for dynamic trajectory planning on FPGA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Bernard Girau
Amine Boumaza
  • Fonction : Auteur
  • PersonId : 830929
This paper presents a parallel hardware implementation of a well-known navigation control method on reconfigurable digital circuits. Trajectories are estimated after an iterated computation of the harmonic functions, given the goal and obstacle positions of the navigation problem. The proposed massively distributed implementation locally computes the direction to choose to get to the goal position at any point of the environment. Changes in this environment may be immediately taken into account, for example when obstacles are discovered during an on-line exploration. The implementation results show that the proposed architecture simultaneously improves speed, power consumption, precision, and environment size.
549-226.pdf (240.86 Ko) Télécharger le fichier
inria-00119491 , version 1 (10-12-2006)
  • HAL Id : inria-00119491 , version 1
Bernard Girau, Amine Boumaza. Embedded harmonic control for dynamic trajectory planning on FPGA. The IASTED International Conference on Artificial Intelligence and Apllications - AIA 2006, Feb 2007, Innsbruck, Australia. ⟨inria-00119491⟩
107 Consultations
213 Téléchargements
