Finite speed propagation of the solutions for the relativistic Vlasov-Maxwell system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
In this paper we investigate the continuous dependence with respect to the initial data of the solutions for the 1D and 1.5D relativistic Vlasov-Maxwell system. More precisely we prove that these solutions propagate with finite speed. We formulate our results in the framework of mild solutions, i.e., the particle densities are solutions by characteristics and the electro-magnetic fields are Lipschitz continuous functions.
main_FiniteSpeed.pdf (196.03 Ko) Télécharger le fichier
inria-00120719 , version 1 (17-12-2006)
inria-00120719 , version 2 (06-01-2007)
inria-00120719 , version 3 (08-01-2007)
inria-00120719 , version 4 (20-02-2008)
  • HAL Id : inria-00120719 , version 1
Mihai Bostan. Finite speed propagation of the solutions for the relativistic Vlasov-Maxwell system. [Research Report] 2006, pp.26. ⟨inria-00120719v1⟩
99 Consultations
345 Téléchargements
