Homogenization of the 1D Vlasov-Maxwell equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
In this paper we investigate the homogenization of the one dimensional Vlasov-Maxwell system. We indicate the rate of convergence towards the limit solution. In the non relativistic case we compute explicitly the limit solution. The theoretical results are illustrated by some numerical simulations.
main_HomVlaMax1D.pdf (182.94 Ko) Télécharger le fichier
inria-00120720 , version 1 (17-12-2006)
inria-00120720 , version 2 (06-01-2007)
inria-00120720 , version 3 (08-01-2007)
inria-00120720 , version 4 (20-02-2008)
  • HAL Id : inria-00120720 , version 1
Mihai Bostan. Homogenization of the 1D Vlasov-Maxwell equations. [Research Report] 2006, pp.19. ⟨inria-00120720v1⟩
170 Consultations
389 Téléchargements
