Abstract : The occurrence of certain incidents in the normal operation of in-vehicle networks, such as bit errors caused by electromagnetic interference (EMI), produces a special form of network partitioning (i.e., a node is temporarily isolated from the rest of the network). Recovering from these situations takes some time, leading to an increase of the message latency (also called response time). This may induce failures of expected hard real-time properties or services of the network. Timeliness of applications may be compromised and may lead to application failures. Thus, methods to analyze the impact of such faults are important.
