Providing QoS in a Grid Application Monitoring Service - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Monitoring distributed applications executed on a computational Grid is challenging since they are executed on several heterogeneous nodes belonging to different administrative domains. An application monitoring service should provide users and administrators with useful and dependable data on the applications executed on the Grid. We present in this paper a grid application monitoring service designed to handle high availability and scalability issues. The service supplies information on application state, on failures and on resource consumption. A set of monitoring mechanisms are used according to grid node nature to effectively monitor the applications. experiments on the Grid'5000 testbed show that the service provides dependable information with a minimal cost on Grid performances.
RR-6070.pdf (178.12 Ko) Télécharger le fichier
inria-00121059 , version 1 (19-12-2006)
inria-00121059 , version 2 (20-12-2006)
inria-00121059 , version 3 (20-12-2006)
  • HAL Id : inria-00121059 , version 2
Thomas Ropars, Emmanuel Jeanvoine, Christine Morin. Providing QoS in a Grid Application Monitoring Service. [Research Report] RR-6070, 2006, pp.16. ⟨inria-00121059v2⟩
Collections
INRIA-RRRT
175 Consultations
67 Téléchargements
