Reports
M/D/1/0 loss system with interference and applications to transmit-only sensor networks
Bartlomiej Blaszczyszyn 1 Bozidar Radunovic 1
1 TREC - Theory of networks and communications
DI-ENS - Département d'informatique de l'École normale supérieure, Inria Paris-Rocquencourt
Abstract : We propose and analyze a probabilistic model of packet reception in the steady state regime of a non-slotted wireless communication channel. It is an extension of the classical M/D/1/0 Erlang's loss model where the {\em interference} created by different packet emissions is introduced by means of a shot-noise process. More precisely, we assume that a given {\em packet is admitted} by the single receiver if this latter is idle at the packet arrival epoch and {\em successfully received} if, in addition, its signal-to-interference-and-noise ratio averaged over the reception period is large enough. As the main result we prove an analog of the Erlang's formula for the ergodic rate of the successfully received packets. Our work is motivated by some applications to transmit-only sensor networks.
Document type :
Reports
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/inria-00121481
Contributor : Rapport de Recherche Inria <>
Submitted on : Thursday, December 21, 2006 - 9:47:00 AM
Last modification on : Tuesday, May 4, 2021 - 2:06:01 PM
Long-term archiving on: : Monday, September 20, 2010 - 5:46:15 PM
RR-6073.pdf
Identifiers
  • HAL Id : inria-00121481, version 2
Collections
Citation
Bartlomiej Blaszczyszyn, Bozidar Radunovic. M/D/1/0 loss system with interference and applications to transmit-only sensor networks. [Research Report] RR-6073, INRIA. 2006, pp.17. ⟨inria-00121481v2⟩
Share
Metrics
Record views
368
Files downloads
341
