Reports
Optimization of complex robot applications under thermal constraints
Abstract : This paper deals with minimum time trajectory optimization along a specified path subject to thermal constraints. We point out here that robots are often integrated in complex robotic cells, and the interactions between the robot and its environment are often difficult or even impossible to modelize. The structure of the optimization problem allows us to decompose the optimization in two levels, the first one being based on models and results of the theory of the calculus of variations, the second one being based on measurements and derivative free algorithms. This decomposition allows us to optimize the velocity profiles efficiently without knowing in advance the interactions between the robot and is environment. We propose here two numerical algorithms for these two levels of the decomposition which show good convergence properties. The resulting optimal velocity profiles are 5 to 10\% faster than classical ones, and have been executed on successfully on a real Stäubli Rx90 manipulator robot.
Complete list of metadatas
https://hal.inria.fr/inria-00121671
Contributor : Matthieu Guilbert <>
Submitted on : Thursday, December 21, 2006 - 3:19:22 PM
Last modification on : Monday, October 8, 2018 - 9:40:09 AM
Document(s) archivé(s) le : Tuesday, April 6, 2010 - 8:09:16 PM
RR.pdf
Identifiers
  • HAL Id : inria-00121671, version 1
Citation
Matthieu Guilbert, Pierre-Brice Wieber, Luc Joly. Optimization of complex robot applications under thermal constraints. [Research Report] 2006, 27 p. ⟨inria-00121671v1⟩
Share
Metrics
Record views
10
Files downloads
24
