A Theory of Objects, 1996. ,
DOI : 10.1007/978-1-4419-8598-9
A formal basis for architectural connection, ACM Transactions on Software Engineering and Methodology, vol.6, issue.3, 1997. ,
DOI : 10.1145/258077.258078
URL : https://hal.archives-ouvertes.fr/hal-00444067
Customization and composition of distributed objects: Middleware abstractions for policy management, Proceedings of the ACM SIGSOFT 6th International Symposium on Foundations of Software Engineering (FSE), 1998. ,
From Distributed Objects to Hierarchical Grid Components, International Symposium on Distributed Objects and Applications (DOA), 2003. ,
DOI : 10.1007/978-3-540-39964-3_78
The Kell Calculus: Operational Semantics and Type System, Proceedings 6th IFIP International Conference on Formal Methods for Open Object-based Distributed Systems (FMOODS 03), 2003. ,
DOI : 10.1007/3-540-47959-7_3
An Open Component Model and Its Support in Java, Lecture Notes in Computer Science, vol.3054, 2004. ,
DOI : 10.1007/978-3-540-24774-6_3
Mobile ambients, An extended abstract appeared in Proceedings of FoSSaCS '98, pp.177-213, 2000. ,
DOI : 10.1016/S0304-3975(99)00231-5
A Theory of Distributed Objects, 2005. ,
Asynchronous and deterministic objects, Proceedings of the 31st ACM SIGACT-SIGPLAN symposium on Principles of programming languages, pp.123-134, 2004. ,
DOI : 10.1145/964001.964012
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.9095
Towards seamless computing and metacomputing in Java. Concurrency: Practice and Experience, pp.11-131043, 1998. ,
Recursive and dynamic software composition with sharing, Proceedings of the 7th ECOOP International Workshop on Component-Oriented Programming, 2002. ,
The semantics of future and an application, Journal of Functional Programming, vol.9, issue.1, pp.1-31, 1999. ,
DOI : 10.1017/S0956796899003329
Behaviour analysis of distributed systems using the tracta approach, Automated Software Engg, vol.6, issue.1, 1999. ,
Compilation and equivalence of imperative objects, FSTTCS: Foundations of Software Technology and Theoretical Computer Science, vol.17, pp.74-87, 1997. ,
MULTILISP: a language for concurrent symbolic computation, ACM Transactions on Programming Languages and Systems, vol.7, issue.4, pp.501-538, 1985. ,
DOI : 10.1145/4472.4478
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.97.1841
The semantics of a simple language for parallel programming ,
Typing confluence Also available as report ERCIM-10, Proceedings of FMICS'97 Consiglio Nazionale Ricerche di Pisa European Research Consortium for Informatics and Mathematics, pp.77-10197, 1997. ,
The Kell Calculus: A Family of Higher-Order Distributed Process Calculi, Lecture Notes in Computer Science, vol.3267, 2005. ,
DOI : 10.1007/3-540-45694-5_19
