Finding low-weight polynomial multiples using discrete logarithm
Finding low-weight multiples of a binary polynomial is a difficult problem arising in the context of stream ciphers cryptanalysis. The classical algorithm to solve this problem is based on a time memory trade-off. We will present an improvement to this approach using discrete logarithm rather than a direct representation of the involved polynomials. This gives an algorithm which improves the theoretical complexity, and is also very flexible in practice.
Cryptographie et sécurité [cs.CR]
