Finding low-weight polynomial multiples using discrete logarithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Frédéric Didier
  • Fonction : Auteur
  • PersonId : 837467
Yann Laigle-Chapuy
  • Fonction : Auteur
  • PersonId : 833446
Finding low-weight multiples of a binary polynomial is a difficult problem arising in the context of stream ciphers cryptanalysis. The classical algorithm to solve this problem is based on a time memory trade-off. We will present an improvement to this approach using discrete logarithm rather than a direct representation of the involved polynomials. This gives an algorithm which improves the theoretical complexity, and is also very flexible in practice.
DidierLaiglechapuy.pdf (99.13 Ko) Télécharger le fichier
inria-00123316 , version 1 (09-01-2007)
inria-00123316 , version 2 (15-01-2007)
inria-00123316 , version 3 (12-07-2007)
Frédéric Didier, Yann Laigle-Chapuy. Finding low-weight polynomial multiples using discrete logarithm. IEEE International Symposium on Information Theory - ISIT'07, Jun 2007, Nice, France. ⟨inria-00123316v2⟩
28 Consultations
171 Téléchargements
