HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Books
Constraint-Based Scheduling: Applying Constraint Programming to Scheduling Problems
Abstract : Constraint Programming is a problem-solving paradigm that establishes a clear distinction between two pivotal aspects of a problem: (1) a precise definition of the constraints that define the problem to be solved and (2) the algorithms and heuristics enabling the selection of decisions to solve the problem. It is because of these capabilities that Constraint Programming is increasingly being employed as a problem-solving tool to solve scheduling problems. Hence the development of Constraint-Based Scheduling as a field of study. The aim of this book is to provide an overview of the most widely used Constraint-Based Scheduling techniques. Following the principles of Constraint Programming, the book consists of three distinct parts: The first chapter introduces the basic principles of Constraint Programming and provides a model of the constraints that are the most often encountered in scheduling problems. Chapters 2, 3, 4, and 5 are focused on the propagation of resource constraints, which usually are responsible for the "hardness" of the scheduling problem. Chapters 6, 7, and 8 are dedicated to the resolution of several scheduling problems. These examples illustrate the use and the practical efficiency of the constraint propagation methods of the previous chapters. They also show that besides constraint propagation, the exploration of the search space must be carefully designed, taking into account specific properties of the considered problem (e.g., dominance relations, symmetries, possible use of decomposition rules). Chapter 9 mentions various extensions of the model and presents promising research directions.
Document type :
Books
Complete list of metadata
https://hal.inria.fr/inria-00123562
Contributor : Philippe Baptiste Connect in order to contact the contributor
Submitted on : Wednesday, January 10, 2007 - 1:12:20 PM
Last modification on : Thursday, March 5, 2020 - 6:21:22 PM
Identifiers
  • HAL Id : inria-00123562, version 1
Collections
Citation
Philippe Baptiste, Claude Le Pape, Wim Nuijten. Constraint-Based Scheduling: Applying Constraint Programming to Scheduling Problems. Kluwer, 2001, International Series in Operations Research and Management Science, 978-0792374084. ⟨inria-00123562⟩
Share
Metrics
Record views
319
