New formulations for the Kissing Number Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Applied Mathematics Année : 2007
Determining the maximum number of $D$-dimensional spheres of radius $r$ that can be adjacent to a central sphere of radius $r$ is known as the Kissing Number Problem (KNP). The problem has been solved for 2, 3 and very recently for 4 dimensions. We present two nonlinear (nonconvex) mathematical programming models for the solution of the KNP. We solve the problem by using two stochastic global optimization methods: a Multi Level Single Linkage algorithm and a Variable Neighbourhood Search. We obtain numerical results for 2, 3 and 4 dimensions.
kissing-dam.pdf (113.92 Ko) Télécharger le fichier
inria-00123758 , version 1 (11-01-2007)
  • HAL Id : inria-00123758 , version 1
Leo Liberti, Pietro Belotti, Sergei Kucherenko, Nelson Maculan. New formulations for the Kissing Number Problem. Discrete Applied Mathematics, 2007, 155 (4), pp.1837-1841. ⟨inria-00123758⟩
202 Consultations
882 Téléchargements
