Shortest path to nonpreemptive schedules of unit-time jobs on two identical parallel machines with minimum total completion time
Abstract : Ideal schedules reach both minimum maximum completion time and minimum total completion time of jobs. It is known that there exist computable in polynomial time ideal nonpreemptive two-machine schedules of unit-time operation jobs with equal release dates and arbitrary precedence constraints on identical parallel machines, in flow shops and open shops. In this paper, we study the possibility of extending these results to the case where release dates can be different. % We establish the complexity status of P2|preced,rj,pj=1|\sumCj and F2|preced,rj,pij=1|\sumCj showing that optimal schedules for these problems can also be found in polynomial time and conjecture that all such schedules are ideal indeed. On the other hand, we show that the ideal schedules in open shops do not always exist.
Type de document :
Article dans une revue
Mathematical Methods of Operations Research (ZOR), springer, 2004, Mathematical Methods of Operations Research (ZOR), 60 (1), pp.145--153
Liste complète des métadonnées
https://hal.inria.fr/inria-00123801
Contributeur : Philippe Baptiste <>
Soumis le : jeudi 11 janvier 2007 - 10:06:05
Dernière modification le : jeudi 10 mai 2018 - 02:06:47
  • HAL Id : inria-00123801, version 1
Collections
Citation
Philippe Baptiste, Vadim Timkovsky. Shortest path to nonpreemptive schedules of unit-time jobs on two identical parallel machines with minimum total completion time. Mathematical Methods of Operations Research (ZOR), springer, 2004, Mathematical Methods of Operations Research (ZOR), 60 (1), pp.145--153. 〈inria-00123801〉
Métriques
Consultations de la notice
49
