An Explicit Control Algorithm for Optical FIFO Queues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
With the recent advances in optical technologies, it has become a challenge to build optical queues with minimal complexity. In [ChangCL06], it was shown that an optical FIFO queue can be constructed recursively by a concatenation of scaled optical memory cells, which in turn are made by 2 x 2 switches and fiber delay lines. However, as the construction is recursive, there is no explicit control algorithm for the 2 x2 switches in [ChangCL06]. The main contribution of this paper is to provide an explicit control algorithm for the 2 x2 switches in that construction. We show that our algorithm has O((log B)^2) space complexity and time complexity for an optical FIFO queue with buffer B.
Mots clés
RRopt.pdf (304.86 Ko) Télécharger le fichier
inria-00123901 , version 1 (11-01-2007)
inria-00123901 , version 2 (12-01-2007)
  • HAL Id : inria-00123901 , version 2
Anne Bouillard, Cheng-Shang Chang. An Explicit Control Algorithm for Optical FIFO Queues. [Research Report] RR-6097, INRIA. 2007, pp.11. ⟨inria-00123901v2⟩
138 Consultations
161 Téléchargements
