Using Controller-Synthesis Techniques to Build Property-Enforcing Layers, Proceedings of the European Symposium on Programming, ESOP'03 number 2618 in LNCS, pp.174-188, 2003. ,
DOI : 10.1007/3-540-36575-3_13
Projection of the Array-OL Specification Language onto the Kahn Process Network Computation Model, 8th International Symposium on Parallel Architectures,Algorithms and Networks (ISPAN'05), 2005. ,
DOI : 10.1109/ISPAN.2005.70
URL : https://hal.archives-ouvertes.fr/inria-00565167
The synchronous languages twelve years later, Proceedings of the IEEE, pp.64-83, 2003. ,
LUSTRE: a declarative language for real-time programming, Proceedings of the 14th ACM SIGACT-SIGPLAN symposium on Principles of programming languages , POPL '87, 1987. ,
DOI : 10.1145/41625.41641
N-sychronous Kahn networks, ACM Symp. on Principles of Programming Languages (PoPL'06), 2006. ,
A Conservative Extension of Synchronous Dataflow with State Machines Jersey city, ACM International Conference on Embedded Software (EMSOFT'05), 2005. ,
A domain-specific language for multi-task systems, applying discrete controller synthesis, Proceedings of the 21st ACM Symposium on Applied Computing, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00000867
An array approach for signal processing design, Sophia-Antipolis conference on Micro-Electronics (SAME'98), System-on-Chip Session, 1998. ,
First version of a data flow procedure language, Programming Symposium, pp.362-376, 1974. ,
DOI : 10.1007/3-540-06859-7_145
Another multidimensional synchronous dataflow : Simulating ARRAY- OL in PTOLEMY II, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00070490
Synchronous Modeling and Analysis of Data Intensive Applications, EURASIP Journal on Embedded Systems, vol.2008, issue.1, 2006. ,
DOI : 10.1007/BF01379404
Use of a real-time declarative language for systolic array design and simulation, International Workshop on Systolic Arrays, 1986. ,
The semantics of simple language for parallel programming, IFIP Congress of Information Processing, pp.471-475, 1974. ,
Introducing control in the Gaspard2 data-parallel metamodel : Synchronous approach, Int'l Workshop on Modeling and Analysis of Real-Time and Embedded Systems (MARTES'05), 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00000911
Mode-Automata: a new domain-specific construct for the development of safe critical systems, Science of Computer Programming, vol.46, issue.3, pp.219-254, 2003. ,
DOI : 10.1016/S0167-6423(02)00093-X
ALPHA : un langage équationnel pour la conception et la programmation d'architectures parallèles synchrones, 1989. ,
data-parallelism and data-flow, Proc. of the 9th International Symposium on Lucid and Intensional Programming, 1996. ,
POLLUX, a LUSTRE-based hardware design environment, Conference on Algorithms and Parallel VLSI Architectures II, 1991. ,
Validation of mixed signal-alpha real-time systems through affine calculus on clock synchronisation constraints, World Congress on Formal Methods, pp.1364-1383, 1999. ,
DOI : 10.1007/3-540-48118-4_22
URL : https://hal.archives-ouvertes.fr/hal-00548887
Compilation Principle of a Specification Language Dedicated to Signal Processing, 6th International Conference on Parallel Computing Technologies (PaCT'2001), 2001. ,
DOI : 10.1007/3-540-44743-1_36
StreamIt: A Language for Streaming Applications, International Conference on Compiler Construction, 2002. ,
DOI : 10.1007/3-540-45937-5_14
LUCID, the dataflow programming language, 1985. ,
