MRF Modeling for Optical Flow Computation From Multistructure Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We propose in this paper a new formulation of the equation of the optical flow enabling to compute global and local motions ofmulti-structure objects (flowers and petals, trees and leaves, ...). The displacement fields are computed using a Markovian Random Field (MRF) model. Local and global components of the vector flow are both explicitly retrieved. The minimization of the Gibbs energy is achieved with a down-scaling approach, in which we first analyze the motion of the compact object, the sub-structures' movement being retrieved in a second stage. We validate and demonstrate the efficiency of our approach on synthetic and real images for various applications.
prinet-icip06.pdf (402.52 Ko) Télécharger le fichier
inria-00124141 , version 1 (12-01-2007)
  • HAL Id : inria-00124141 , version 1
  • PRODINRA : 251705
Veronique Prinet, C. Cassisa, F.F. Tang. MRF Modeling for Optical Flow Computation From Multistructure Objects. IEEE International Conference on Image Processing (ICIP), Oct 2006, Atlanta/USA, United States. pp.1093-1096. ⟨inria-00124141⟩
143 Consultations
256 Téléchargements
