An example on approximation by fat arcs and fat biarcs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2006
Fat arcs form bounding boxes for planar curves. An example on approximation by fat arcs, provided by Qun and Rokne, is corrected. The third derivative of the given curve segment under the polar coordinate system is increasing only at the beginning of the curve segment, and then decreasing, rather than monotonically increasing for the whole curve segment. Some numerical data are corrected as well.
Mots clés
inria-00124253 , version 1 (12-01-2007)
inria-00124253 , version 2 (15-09-2010)
Jun-Hai Yong, Xiao Chen, Jean-Claude Paul. An example on approximation by fat arcs and fat biarcs. Computer-Aided Design, 2006, Computer-Aided Design, 38 (5), pp.515--517. ⟨10.1016/j.cad.2006.01.003⟩. ⟨inria-00124253v1⟩
194 Consultations
213 Téléchargements
