Abstract : Fat arcs form bounding boxes for planar curves. An example on approximation by fat arcs, provided by Qun and Rokne, is corrected. The third derivative of the given curve segment under the polar coordinate system is increasing only at the beginning of the curve segment, and then decreasing, rather than monotonically increasing for the whole curve segment. Some numerical data are corrected as well.
https://hal.inria.fr/inria-00124253 Contributor : Thss TsinghuaConnect in order to contact the contributor Submitted on : Wednesday, September 15, 2010 - 8:36:18 AM Last modification on : Friday, February 4, 2022 - 3:08:32 AM
Jun-Hai yong, Xiao Chen, Jean-Claude Paul. An example on approximation by fat arcs and fat biarcs. Computer-Aided Design, Elsevier, 2006, 38 (5), pp.515-517. ⟨inria-00124253v2⟩
