Normal Cone Approximation and Offset Shape Isotopy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Frédéric Chazal
David Cohen-Steiner
  • Fonction : Auteur
  • PersonId : 833472
André Lieutier
  • Fonction : Auteur
  • PersonId : 835777
This work adresses the problem of the approximation of the normals of the offsets of general compact sets in euclidean spaces. It is proven that for general sampling conditions, it is possible to approximate the gradient vector field of the distance to general compact sets. These conditions involve the $\mu$-reach of the compact set, a recently introduced notion of feature size. As a consequence, we provide a sampling condition that is sufficient to ensure the correctness up to isotopy of a reconstruction given by an offset of the sampling. We also provide a notion of normal cone to general compact sets which is stable under perturbation.
ApproxGradRR.pdf (305.63 Ko) Télécharger le fichier
inria-00124825 , version 1 (16-01-2007)
inria-00124825 , version 2 (20-01-2007)
  • HAL Id : inria-00124825 , version 1
Frédéric Chazal, David Cohen-Steiner, André Lieutier. Normal Cone Approximation and Offset Shape Isotopy. [Research Report] RR-6100, 2007, pp.21. ⟨inria-00124825v1⟩
Collections
INRIA-RRRT
197 Consultations
377 Téléchargements
