Algorithms for programmers (working title) Draft version of, 2007. ,
The computation of ? to 29,360,000 decimal digits using Borwein's quartically convergent algorithm, Math. Comp, vol.50, pp.283-296, 1988. ,
FFTs in external or hierarchical memory, The Journal of Supercomputing, vol.5, issue.1, pp.23-35, 1990. ,
DOI : 10.1007/BF00162341
Multidigit multiplication for mathematicians, 2001. ,
Fast multiplication and its applications, 2004. ,
Removing redundancy in high-precision Newton iteration, 2004. ,
MULTIPLE-PRECISION ZERO-FINDING METHODS AND THE COMPLEXITY OF ELEMENTARY FUNCTION EVALUATION, Analytic Computational Complexity, pp.151-176, 1975. ,
DOI : 10.1016/B978-0-12-697560-4.50014-9
Factorization of the eighth Fermat number, Mathematics of Computation, vol.36, issue.154, pp.627-630, 1981. ,
DOI : 10.1090/S0025-5718-1981-0606520-5
Parametrizable behavioral IP module for a data-localized low-power FFT, 1999 IEEE Workshop on Signal Processing Systems. SiPS 99. Design and Implementation (Cat. No.99TH8461), pp.635-644, 1999. ,
DOI : 10.1109/SIPS.1999.822370
Discrete weighted transforms and large-integer arithmetic, Mathematics of Computation, vol.62, issue.205, pp.305-324, 1994. ,
DOI : 10.1090/S0025-5718-1994-1185244-1
Prime Numbers: A Computational Perspective, 2000. ,
DOI : 10.1007/978-1-4684-9316-0
High-precision division and square root, ACM Transactions on Mathematical Software, vol.23, issue.4, pp.561-589, 1997. ,
DOI : 10.1145/279232.279237
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.25.1679
The analysis of algorithms, Actes du Congrès International des Mathématiciens de, pp.269-274, 1970. ,
Fast modular transforms via division, 13th Annual Symposium on Switching and Automata Theory (swat 1972), pp.90-96, 1972. ,
DOI : 10.1109/SWAT.1972.5
Rapid multiplication modulo the sum and difference of highly composite numbers, Mathematics of Computation, vol.72, issue.241, pp.387-395, 2003. ,
DOI : 10.1090/S0025-5718-02-01419-9
Schnelle Berechnung von Kettenbruchentwicklungen, Acta Informatica, vol.1, issue.2, pp.139-144, 1971. ,
DOI : 10.1007/BF00289520
12-1 is up to 2.3 times faster than GMP 4.1.4 for large integer multiplication, 2005. ,
Reduce everything to multiplication Computing by the Numbers: Algorithms, Precision, and Complexity, Workshop for Richard Brent's 60th birthday, 2006. ,
The truncated fourier transform and applications, Proceedings of the 2004 international symposium on Symbolic and algebraic computation , ISSAC '04, pp.290-296, 2004. ,
DOI : 10.1145/1005285.1005327
Modern Computer Algebra, 1999. ,
DOI : 10.1017/CBO9781139856065
The Great Internet Mersenne Prime Search ,
20 Years of ECM, Proceedings of the 7th Algorithmic Number Theory Symposium (ANTS VII), pp.525-542, 2006. ,
DOI : 10.1007/11792086_37
URL : https://hal.archives-ouvertes.fr/inria-00070192
