Knowledge-Intensive Case- Based Reasoning and Sustained Learning, Proc. of the 9th European Conference on Artificial Intelligence (ECAI'90), 1990. ,
DOI : 10.1007/978-3-540-28631-8_1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.139.4426
Principles of Data Mining, Drug Safety, vol.15, issue.2, 2001. ,
DOI : 10.2165/00002018-200730070-00010
Learning adaptation rules from a case-base, Advances in Case-Based Reasoning ? Third European Workshop, EWCBR'96, LNAI 1168, pp.179-192, 1996. ,
DOI : 10.1007/BFb0020610
Learning Adaptation Rules from Cases Master's thesis, Trinity College Using Case-Base Data to Learn Adaptation Knowledge for Design, Proceedings of the 17th International Joint Conference on Artificial Intelligence (IJCAI'01), pp.1011-1016, 1997. ,
Acquiring Case Adaptation Knowledge: A Hybrid Approach Inside Case-Based Reasoning Transferring Case Knowledge to Adaptation Knowledge: An Approach for Case-Base Maintenance, AAAI/IAAI, pp.684-689295, 1989. ,
Using adaptation knowledge to retrieve and adapt design cases. Knowledge-Based Systems, pp.127-135, 1996. ,
DOI : 10.1016/0950-7051(95)01024-6
CHARM: An Efficient Algorithm for Closed Itemset Mining, SIAM International Conference on Data Mining SDM'02, pp.33-43, 2002. ,
DOI : 10.1137/1.9781611972726.27
