Vlasov laser-plasma interaction simulations with a moving grid
Nicolas Crouseilles 1 Alain Ghizzo 1 Stéphanie Salmon 1, 2
1 CALVI - Scientific computation and visualization
IRMA - Institut de Recherche Mathématique Avancée, LSIIT - Laboratoire des Sciences de l'Image, de l'Informatique et de la Télédétection, Inria Nancy - Grand Est, IECL - Institut Élie Cartan de Lorraine
Abstract : The present work focuses on the numerical resolution of a reduced $1$D Vlasov-Maxwell system introduced recently in the physical literature for studying laser-plasma interaction. This system can be seen as a standard Vlasov equation in which the force term is split into two terms: the classical electrostatic field obtained from the Poisson's equation and a magnetic term evolving through Maxwell's type equations. A semi-Lagrangian code is used to study the interaction of ultrashort electromagnetic pulse with plasma; however during the major part of the simulation, many of the grid points are wasted. We then introduce a dynamic mesh which allows us to consider the part of the phase space where the distribution function is not zero.
Type de document :
Rapport
[Research Report] RR-6109, INRIA. 2007
Liste complète des métadonnées
https://hal.inria.fr/inria-00127747
Contributeur : Rapport de Recherche Inria <>
Soumis le : mardi 30 janvier 2007 - 10:13:39
Dernière modification le : mardi 20 février 2018 - 13:54:01
Document(s) archivé(s) le : mardi 21 septembre 2010 - 12:03:07
Fichiers
RR-6109.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00127747, version 2
Citation
Nicolas Crouseilles, Alain Ghizzo, Stéphanie Salmon. Vlasov laser-plasma interaction simulations with a moving grid. [Research Report] RR-6109, INRIA. 2007. 〈inria-00127747v2〉
Métriques
Consultations de la notice
380
Téléchargements de fichiers
122
