Dynamic XML documents with distribution and replication, ACM SIGMOD Int. Conf. on Management of Data, pp.527-538, 2003. ,
P-Grid, ACM SIGMOD Record, vol.32, issue.3, pp.29-33, 2003. ,
DOI : 10.1145/945721.945729
The chatty web, Proceedings of the twelfth international conference on World Wide Web , WWW '03, pp.197-206, 2003. ,
DOI : 10.1145/775152.775180
Updates in highly unreliable, replicated peer-to-peer systems, Conf. on Distributed Computing Systems (ICDCS), pp.76-85, 2003. ,
Data management in the APPA P2P system, Journal of Grid Computing, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00695035
Design and implementation of APPA. Global Data Management, 2006. ,
Top-k Query Processing in the APPA P2P System, Int. Conf. on High Performance Computing for Computational Science (VecPar), pp.158-171, 2007. ,
DOI : 10.1007/978-3-540-71351-7_13
URL : https://hal.archives-ouvertes.fr/inria-00482362
Replication and query processing in the APPA data management system, Int. Workshop on Distributed Data and Structures (WDAS), pp.19-33, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00688795
Reducing network traffic in unstructured P2P systems using top-k queries, Journal of Distributed and Parallel Databases, vol.19, issue.2-3, pp.67-86, 2006. ,
An efficient mechanism for processing top-k queries in DHTs Journées Bases de Données Avancées (BDA) Androutsellis-Theotokis and D. Spinellis. A survey of peer-to-peer content distribution technologies, ACM Computing Surveys, vol.36, issue.4, pp.335-371, 2004. ,
Scalable, efficient range queries for grid information services A survey of data management in peer-to-peer systems, Proc. of the IEEE Int. Conf. on P2P computing, pp.33-40, 2002. ,
Searching in high-dimensional spaces: Index structures for improving the performance of multimedia databases, ACM Computing Surveys, vol.33, issue.3, pp.322-373, 2001. ,
DOI : 10.1145/502807.502809
Data management for peer-to-peer computing: a vision, Proc of the Int. Workshop on the Web and Databases (WebDB), pp.89-94, 2002. ,
Pagoda, Proceedings of the sixteenth annual ACM symposium on Parallelism in algorithms and architectures , SPAA '04, pp.170-179, 2004. ,
DOI : 10.1145/1007912.1007938
Space/time tradeoffs in hash coding with allowable errors, Communications of the ACM, vol.13, issue.7, pp.422-426, 1970. ,
Progressive distributed topk retrieval in peer-to-peer networks, Proc. of the Int. Conf. on Data Engineering (ICDE), pp.174-185, 2005. ,
Distributed top-k monitoring, Proceedings of the 2003 ACM SIGMOD international conference on on Management of data , SIGMOD '03, pp.28-39, 2003. ,
DOI : 10.1145/872757.872764
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.108.4136
Scribe: a large-scale and decentralized application-level multicast infrastructure, IEEE Journal on Selected Areas in Communications, vol.20, issue.8, pp.1489-1499, 2002. ,
DOI : 10.1109/JSAC.2002.803069
RDFPeers, Proceedings of the 13th conference on World Wide Web , WWW '04, pp.650-657, 2004. ,
DOI : 10.1145/988672.988760
MAAN: a multi-attribute addressable network for grid information services, Int. Workshop on Grid Computing, pp.184-191, 2003. ,
Routing indices for peer-to-peer systems, Proceedings 22nd International Conference on Distributed Computing Systems, pp.23-33, 2002. ,
DOI : 10.1109/ICDCS.2002.1022239
Optimizing top-k selection queries over multimedia repositories, IEEE Transactions on Knowledge and Data Engineering, vol.16, issue.8, pp.992-1009, 2004. ,
DOI : 10.1109/TKDE.2004.30
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.8588
An evaluation of scalable application-level multicast built using peer-to-peer overlays. Annual Joint Conf, of the IEEE Computer and Communications Societies (INFOCOM), pp.1510-1520, 2003. ,
Protecting free expression online with Freenet Searching in metric spaces with user-defined and approximate distances, RR IEEE Internet Computing ACM Transactions on Database Systems, vol.6, issue.274, pp.6112-6152, 2002. ,
PlanetP: using gossiping to build content addressable peer-to-peer information sharing communities, High Performance Distributed Computing, 2003. Proceedings. 12th IEEE International Symposium on, pp.236-249, 2003. ,
DOI : 10.1109/HPDC.2003.1210033
Making Gnutella-like P2P systems scalable, ACM SIGCOMM Conf. on Applications, Technologies, Architectures, and Protocols for Computer Communications, pp.407-418, 2003. ,
Efficient top-K query calculation in distributed networks, Proceedings of the twenty-third annual ACM symposium on Principles of distributed computing , PODC '04 ,
DOI : 10.1145/1011767.1011798
The FreeHaven project: distributed anonymous storage service. Workshop on Design Issues in Anonymity and Unobservability, pp.67-95, 2000. ,
Open Problems in Data-Sharing Peer-to-Peer Systems, Int. Conf. on Database Theory (ICDT, pp.1-15, 2003. ,
DOI : 10.1007/3-540-36285-1_1
Learning to match ontologies on the Semantic Web, ACM Int. Conf. on Management of Data, pp.303-319, 2002. ,
DOI : 10.1007/s00778-003-0104-2
Optimal aggregation algorithms for middleware, Proceedings of the twentieth ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '01, pp.614-656, 2003. ,
DOI : 10.1145/375551.375567
Approximate range selection queries in peer-to-peer systems, First Biennial Conference on Innovative Data Systems Research (CIDR), pp.141-151, 2003. ,
The impact of DHT routing geometry on resilience and proximity, Proceedings of the 2003 conference on Applications, technologies, architectures, and protocols for computer communications , SIGCOMM '03, pp.381-394, 2003. ,
DOI : 10.1145/863955.863998
Optimizing multi-feature queries for image databases, Int. Conf. on Very Large Databases (VLDB) INRIA [Gnu06] Gnutella, pp.419-428, 2000. ,
An adaptive protocol for efficient support of range queries in DHT-based systems, Conf. on Network Protocols (ICNP), pp.239-250, 2004. ,
Complex Queries in DHT-based Peer-to-Peer Networks, Int. Workshop on Peerto-Peer Systems (IPTPS), pp.242-259, 2002. ,
DOI : 10.1007/3-540-45748-8_23
Piazza, Proceedings of the twelfth international conference on World Wide Web , WWW '03, pp.556-567, 2003. ,
DOI : 10.1145/775152.775231
Skipnet: a scalable overlay network with practical locality properties, USENIX Symp. on Internet Technologies and Systems, pp.113-126, 2003. ,
Index-driven similarity search in metric spaces, ACM Transactions on Database Systems, vol.28, issue.4, pp.517-580, 2003. ,
DOI : 10.1145/958942.958948
Scalability issues in large peer-topeer networks: a case study of Gnutella, 2001. ,
Modelling large-scale peer-to-peer networks and a case study of Gnutella Master's thesis, ECECS Department Indra: a peer-to-peer approach to network intrusion detection and prevention, IEEE Int. Workshops on Enabling Technologies: Infrastructure for Collaborative Enterprises, pp.226-231, 2000. ,
Ocean- Store: an architecture for global-scale persistent storage, ACM Int. Conf. on Architectural Support for Programming Languages and Operating Systems (AS- PLOS), pp.190-201, 2000. ,
A local search mechanism for peer-to-peer networks, Proceedings of the eleventh international conference on Information and knowledge management , CIKM '02, pp.6112-300, 2002. ,
DOI : 10.1145/584792.584842
Approximate NN queries on streams with guaranteed error, Int. Conf. on Very Large Databases (VLDB), pp.804-815, 2004. ,
DOI : 10.1016/b978-012088469-8.50071-1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.8872
SOS: secure overlay services, ACM SIGCOMM Conf. on Applications, Technologies, Architectures, and Protocols for Computer Communications, pp.61-72, 2002. ,
Search and replication in unstructured peer-to-peer networks, ACM Int. Conf. on Supercomputing (ICS), pp.84-95, 2002. ,
Data integration: a theoretical perspective, ACM Symp. on Principles of Distributed Computing, pp.233-246, 2002. ,
Flexible and robust large scale multicast using i3, 2002. ,
Folding@Home and Genome@Home: using distributed computing to tackle previously intractable problems in computational biology, Modern Methods in Computational Biology, 2003. ,
Searching techniques in peer-to-peer networks. Handbook of Theoretical and Algorithmic Aspects of Ad Hoc, Sensor, and Peer-to-Peer Networks, 2006. ,
Reconciliation in the APPA P2P system, 12th International Conference on Parallel and Distributed Systems, (ICPADS'06), pp.401-410, 2006. ,
DOI : 10.1109/ICPADS.2006.91
URL : https://hal.archives-ouvertes.fr/inria-00378878
Corpus-based schema matching Probabilistic scalable P2P resource location services, Proc. of the Int. Conf. on Data Engineering (ICDE), pp.57-68, 2002. ,
Kademlia: a peer-to-peer information system based on the XOR metric. Int. Workshop on Peer-to-Peer Systems, pp.53-65, 2002. ,
Viceroy, Proceedings of the twenty-first annual symposium on Principles of distributed computing , PODC '02, pp.183-192, 2002. ,
DOI : 10.1145/571825.571857
Defining peer-to-peer data integration using both as view rules Information Systems and Peerto-Peer Computing, Int. Workshop on Databases, pp.91-107, 2004. ,
KLEE: a framework for distributed top-k query algorithms, Int. Conf. on Very Large Databases (VLDB), pp.637-648, 2005. ,
Query processing issues in image (multimedia) databases, Proceedings 15th International Conference on Data Engineering (Cat. No.99CB36337), pp.22-29, 1999. ,
DOI : 10.1109/ICDE.1999.754894
Design issues and challenges for RDF- and schema-based peer-to-peer systems, ACM SIGMOD Record, vol.32, issue.3, pp.41-46, 2003. ,
DOI : 10.1145/945721.945731
Relational data sharing in peer-based data management systems, ACM SIGMOD Record, vol.32, issue.3, pp.59-64, 2003. ,
DOI : 10.1145/945721.945734
Principles of Distributed Database Systems, 1999. ,
Accessing nearby copies of replicated objects in a distributed environment, ACM Symp. on Parallel Algorithms and Architectures, pp.311-320, 1997. ,
Update propagation strategies to improve freshness in lazy master replicated databases, The VLDB Journal The International Journal on Very Large Data Bases, vol.8, issue.3-4, pp.305-318, 2000. ,
DOI : 10.1007/s007780050010
Filtered document retrieval with frequency-sorted indexes, Journal of the American Society for Information Science, issue.10, pp.47-749, 1996. ,
Pastry: scalable, distributed object location and routing for large-scale peer-to-peer systems, IFIP/ACM Int. Conf. on Distributed Systems Platforms, pp.329-350, 2001. ,
Storage management and caching in PAST, a large-scale, persistent peer-to-peer storage utility, ACM Symp. on Operating Systems Principles, pp.188-201, 2001. ,
A scalable content-addressable network, ACM SIGCOMM Conf. on Applications, Technologies , Architectures, and Protocols for Computer Communications, pp.161-172, 2001. ,
DOI : 10.1145/964723.383072
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.1538
Probabilistic location and routing. Annual Joint Conf, of the IEEE Computer and Communications Societies (INFOCOM), pp.6112-1248, 2002. ,
DOI : 10.1109/infcom.2002.1019375
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.16.3696
Query processing over peerto-peer data sharing systems, 2002. ,
Chord: a scalable peer-to-peer lookup service for internet applications, ACM Conf. on Applications, Technologies, Architectures, and Protocols for Computer Communications (SIGCOMM), pp.149-160, 2001. ,
PeerDB: a P2P-based system for distributed data sharing, Proceedings 19th International Conference on Data Engineering (Cat. No.03CH37405), pp.633-644, 2003. ,
DOI : 10.1109/ICDE.2003.1260827
The Piazza peer data management project, ACM SIGMOD Record, vol.32, issue.3, pp.47-52, 2003. ,
Towards a unifying framework for complex query processing over structured peer-to-peer data networks Information Systems and Peer-to-Peer Computing Adaptive probabilistic search (APS) for peer-to-peer networks, Int.Workshop on Databases, pp.169-183, 2003. ,
A Comparison of peer-to-peer search methods, Int. Workshop on the Web and Databases (WebDB), pp.61-66, 2003. ,
Scaling access to heterogeneous data sources with DISCO, IEEE Transactions on Knowledge and Data Engineering, vol.10, issue.5, pp.808-823, 1998. ,
DOI : 10.1109/69.729736
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.133.9176
The Ecobase environmental information system: applications, architecture and open issues, ACM SIGMOD Record, vol.30, issue.3, pp.70-75, 2000. ,
Information integration using logical views, Proc. of the Int. Conf. on Database Theory (ICDT), pp.19-40, 1997. ,
Parallel database systems: open problems and new issues. Distributed and Parallel Databases, pp.137-165, 1993. ,
Security applications of peer-to-peer networks, W3C01] W3C: World Wide Web consortium on semantic Web activities, pp.195-205, 2001. ,
DOI : 10.1016/j.comnet.2004.01.002
Dataflow query execution in a parallel mainmemory environment, Int. Conf. on Parallel and Distributed Information Systems (PDIS), pp.68-77, 1991. ,
Publius: a robust, tamper-evident, censorshipresistant , web publishing system, pp.59-72, 2000. ,
Mediators in the architecture of future information systems, IEEE Computer, vol.25, issue.3, pp.38-49, 1992. ,
Load balancing with multiple hash functions in peer-to-peer networks, IEEE Int. Conf. on Parallel and Distributed Systems (ICPADS), pp.411-420, 2006. ,
Improving search in peer-to-peer networks, Proceedings 22nd International Conference on Distributed Computing Systems, pp.5-14, 2002. ,
DOI : 10.1109/ICDCS.2002.1022237
Tapestry: A Resilient Global-Scale Overlay for Service Deployment, IEEE Journal on Selected Areas in Communications, vol.22, issue.1, pp.41-53, 2004. ,
DOI : 10.1109/JSAC.2003.818784
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.10.1904
