Identifiabilty of systems described by convolution equations, Automatica, vol.41, issue.3, pp.505-512, 2005. ,
DOI : 10.1016/j.automatica.2004.11.013
A Razumikhin-type lemma for functional differential equations with application to adaptive control, Automatica, vol.35, issue.5, pp.809-818, 1999. ,
DOI : 10.1016/S0005-1098(98)00227-1
Observer-based H??? controller design for state delayed linear systems, Automatica, vol.32, issue.7, pp.1073-1075, 1996. ,
DOI : 10.1016/0005-1098(96)00014-3
Optimization and nonsmooth analysis, Series of Monographs and Advanced Texts, 1983. ,
DOI : 10.1137/1.9781611971309
Linear functional observers for systems with delays in state variables, IEEE Transactions on Automatic Control, vol.46, issue.3, pp.491-496, 2001. ,
DOI : 10.1109/9.911430
Design of reduced-order observers without internal delays, IEEE Transactions on Automatic Control, vol.44, issue.9, pp.1711-1713, 1999. ,
DOI : 10.1109/9.788537
Preserving stability/performance when facing an unknown time-delay, Control Engineering Practice, vol.9, issue.12, pp.1319-1325, 2001. ,
DOI : 10.1016/S0967-0661(01)00078-8
Adaptive quasioptimal filters/observers with discontinuous parameters. Automation and Remote Control, pp.44-91167, 1984. ,
Sliding-mode observers based on equivalent control method, [1992] Proceedings of the 31st IEEE Conference on Decision and Control, pp.2368-2370, 1992. ,
DOI : 10.1109/CDC.1992.371368
Delayless observers for systems with delay, IEEE Transactions on Automatic Control, vol.31, issue.3, pp.258-259, 1986. ,
DOI : 10.1109/TAC.1986.1104228
Differential equations with discontinuous right-hand side, 1988. ,
DOI : 10.1090/trans2/042/13
Adaptive stabilization of delay differential systems with unknown uncertainty bounds, International Journal of Control, vol.71, issue.2, pp.259-275, 1998. ,
DOI : 10.1080/002071798221867
A state observer for nonlinear delay systems, Proceedings of the 37th IEEE Conference on Decision and Control (Cat. No.98CH36171), pp.355-360, 1998. ,
DOI : 10.1109/CDC.1998.760699
Introduction to Functional Differential Equations, Applied Math. Sciences, vol.99, 1993. ,
DOI : 10.1007/978-1-4612-4342-7
Robust stability of uncertain time delay systems, IEEE Trans. Aut. Control, issue.11, pp.452169-2173, 2000. ,
Introduction to the theory and applications of functional differential equations, Kluwer Acad, 1999. ,
DOI : 10.1007/978-94-017-1965-0
Stability of functional differential equations, 1986. ,
Identifiability analysis of linear delay-differential systems, IMA Journal of Mathematical Control and Information, vol.19, issue.1 and 2, pp.73-81, 2002. ,
DOI : 10.1093/imamci/19.1_and_2.73
An asymptotic modal observer for linear autonomous time lag systems, IEEE Transactions on Automatic Control, vol.40, issue.7, pp.1291-1294, 1995. ,
DOI : 10.1109/9.400473
A novel identifcation method for time delay processes, ECC99 (5 th European Control Conf.), Karslruhe, 1999. ,
Ring models for delay-differential systems, Automatica, vol.12, issue.5, pp.529-531, 1976. ,
DOI : 10.1016/0005-1098(76)90013-3
Delay Effects on Stability, LNCIS, vol.269, 2001. ,
Adaptive identification of linear time-delay systems, International Journal of Robust and Nonlinear Control, vol.31, issue.9, 2003. ,
DOI : 10.1002/rnc.850
Parameter identification of linear delay systems, International Journal of Control, vol.5, issue.2, pp.595-627, 1989. ,
DOI : 10.1049/piee.1971.0207
Variable structure and sliding mode control. chapter in The Control Handbook a Volume in the Electrical Engineering Handbook Series, 1996. ,
Time-delay systems: an overview of some recent advances and open problems, Automatica, vol.39, issue.10, pp.1667-1694, 2003. ,
DOI : 10.1016/S0005-1098(03)00167-5
Sliding mode control in dynamic systems, International Journal of Control, vol.1, issue.4, pp.55-41029, 1992. ,
DOI : 10.1016/0005-1098(76)90076-5
Unique identification of coefficient matrices, time delay and initial functions of functionnal differential equations, Journal of Mathematical Systems, Estimation and Control, vol.5, issue.3, pp.323-344, 1995. ,
New trends in design of observers for time-delay systems, Kybernetica, vol.37, issue.4, pp.427-458, 2001. ,
Finite Spectrum Assignment Control of Unstable Time Delay Processes with Relay Tuning, Industrial & Engineering Chemistry Research, vol.37, issue.4, pp.1351-1357, 1998. ,
DOI : 10.1021/ie970765o
Time delay estimation in continuous linear time-invariant systems, IEEE Transactions on Automatic Control, vol.39, issue.4, pp.823-827, 1994. ,
DOI : 10.1109/9.286261
Sliding modes in control optimization, 1992. ,
DOI : 10.1007/978-3-642-84379-2
Identification problems in functional differential equations, 36 th IEEE CDC97 (Conf. on Dec. and Control), pp.4409-4413, 1997. ,
Robust stability and adaptive control of time-varying neutral systems, Proceedings of the 38th IEEE Conference on Decision and Control (Cat. No.99CH36304), pp.4690-4695, 1999. ,
DOI : 10.1109/CDC.1999.833283
Controllability of systems described by convolutionnal or delay-differential equations, SIAM Journal of Control and Optimization, vol.39, issue.3, pp.728-756, 2000. ,
Robust H??? observer design of linear state delayed systems with parametric uncertainty: the discrete-time case, Automatica, vol.35, issue.6, pp.1161-1167, 1999. ,
DOI : 10.1016/S0005-1098(99)00008-4
On-line parameter identification of linear time-delay, Systemsin Proc. IEEE CDC 02, 2002. ,
Reachability of a Class of Infinite-Dimensional Linear Systems: An External Approach with Applications to General Neutral Systems, SIAM Journal on Control and Optimization, vol.27, issue.1, pp.217-234, 1989. ,
DOI : 10.1137/0327012
Functional observer and state feedback for input time-delay systems, International Journal of Control, vol.66, issue.4, pp.603-617, 1997. ,
DOI : 10.1080/002071797224612
